Archaea
- Oct 19, 2004
I'm a PC tech and pretty savy around XP but I've not played with XP 64 bit yet too much at all. I recently bought a 64 bit XP OS to install on a AMD 64 bit 3200 machine for my wife.
I installed Java 1.5.0.8
My wife must have accidentally downloaded a file of some sort/spyware/ because the java disappeared from browser (lost integration) I looked in the control panel Add/Remove programs and there were three versions of Java in there.
1.5.0.6
1.5.0.7
1.5.0.8
However there were no icons in the Control Panel for the Java app which is important because the control panel java icon is where you go to integrate the java app into the browser.
I logged in as administrator, removed all three versions and reinstall version 1.5.0.9, and still there was no control panel icon and no browser integration.
Any ideas? The 64 bit OS isn't all its cracked up to be I don't think...I've exp driver problems with it in various levels mostly with driver and browser support and can't even run any virus checker that I have, including a recently purchased Symatec 2007.
1.5.0.6
1.5.0.7
1.5.0.8
