When I turned on my computer today, I got to the "Windows is starting" screen but there was no glowing icon - just the text frozen. I noted that the hard drive activity light barely flickered for a millisecond then lit up no more. Thinking a hard drive problem, tried to install Windows on a spare drive but got the same frozen "Windows is starting" screen. Then removed my GTX 660 and connected the monitor directly to motherboard video thinking a PSU issue, that a lighter load would help start Windows and diagnose the problem. No change. Then disconnected a USB hub and it's attached devices not expecting change because the removal of a video card should make a bigger difference than devices on a USB hub. But really surprised that Windows loaded and operated normally, at least playing videos. Then I checked Hardware monitor and the CPU at 61c idle! So i checked the CPU and observed caked on dust, lots of it in the groves of the the heat sink. I will clean everything and reseat CPU but my question is : is this a caked on dust the problem? I checked temps just a couple of days ago and it was 25c. The sequence of events doesn't make sense to me. Did removing the USB stuff make a difference, or was it coincidence. Or was it that the dust build up reached a threshold? To look at it, I'm thinking maybe because there is really a lot of dust buildup that I hadn't noticed before. So I'm gonna pick up thermal paste, but in the interim, I'd appreciate the sage enlightenment that I know certain members here are capable of bestowing.
[edit] well maybe dust isn't the issue because this happens at startup where I observed 45c in the bios after warm up.
