Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
windows xp cannot format any removeable storage drives, such as floppy or mp3 players
it says the item is not formatted, then asks to format it
i attempt, and then it fails right when it finishes
anyone know how to fix this?
check "quick format" box when you format anything like that. I have an LS120. It will full format 1.44 floppies OK but, it hangs, same as you describe, on the 120mb disks, unless I check the "quick format" box when I format them. Same goes for my usb flash drive. Hope it helps. With regular 1.44 floppies I would swap out your floppie cable to see if that is a problem. It should full format those without issue.
quick format doesnt work either
and changing out the floppy drive cord didnt help
i dont think the problem has anything to do with the floppy drive, like i thought earlier
because i tried a mp3 player and it says it needs formatted, and i try and it does the same crap as the floppy drive
