Alrighty, I finally decided to try Virtualization.
I installed Windows XP Mode for Windows 7 64 bit.
My goals are simple, but I would like a little guidance on accomplishing them.
Basically I went Windows 95 - Windows 98 - Windows XP - Windows 7 now.
I have quite a few programs that do not run on Windows 7 properly, so I want to set up a Windows XP and Windows 98 Virtual Machine. I have already set up the XP mode within Windows 7, so I do have a virtual xp running.
Goals: Get all my programs and games running, including the ones that only run on Windows XP and or Windows 98. No programs need internet access, so I disabled that intergration. Some games could use it sometimes, If I decide to play online, however I would only enable it then.
Window XP VM:
Can I autologin the VM and remove its password? I did, and it worked, however when I clicked Enable Shell Intergration, it tried to login with a password. Do I delete the credentials then it works? Didn't mess with it to much, as don't want to deal with the hassle, hehe. What does Shell intergration actually do? Is it needed?
I disabled Networking, because no applications need to access the internet, if so, then I can enable then, I should be ok with no firewall or antivirus etc right? It's just for legit bought programs, no downloading will be done on the VM.
How do I install the Radeon drivers? I am running a Radeon 3870x2, but it shows up as a Trio S3. It's working but I would like if possible be able to utilize the power of my Radeon. I am limited to 1920x1200 (16:10), on this Trio, when I wanted to get my full resolution of 2560x1600 on the vm (is this possible?) Also when applications launch at full screen, ie at 800x600, will they take over the screen if I have it in fullscreen?
I made one of my external hardrives for just the VM stuff, so anything that needs to be installed there, goes there.
Windows 98 VM:
I still have my Windows 98 Upgrade CD, but my Windows 95 was OEM. Also I did find a Windows 98 SE, that's Portuguese, (I speak Portuguese) So I can use that correct? Can I set it up just like XP mode? Use Radeon, etc? I can prob just set it to English anyhow right?
Honestly, all I need the VMs are to run actual programs/games, that's pretty much it, my ultimate goal, is shortcut on my Windows 7 desktop, double click it, that will auto launch the application/vm in full screen, as if it was native in Windows 7.
Thanks
Window XP VM:
Windows 98 VM:
Thanks
