... i'm trying to get all my updates up to date before installing SP2, but there's one update that I haven't been able to install for quite a bit of time. I get the following error and code readings after doing an update:
I've tried stopping and restarting the Windows Update service in Command Prompt as directed by Windows Help but that didn't solve anything.
I've even downloaded the exact update standalone from Microsoft's website and I still can't install it...
Any ideas on how to install this successfully?
One other thing... before I tried to install this update, I attempted to install SP2, but after it creates a restore point and scans the system, it says Installation was Unsuccessful and to make sure the Update readiness tool is installed... where do I find that and is it really needed?
Thanks for your help guys!
EDIT: I was forgot to point out that while the system tries to install the update above (SQL), this window pops up called HotFix and says to close the program or get help/send information to Microsoft...
Security Update for SQL Server 2005 Service Pack 2 (KB961371) - Failed
Error Found: Code C0000005
