Anyone know how to disable the annoying clicking sound everytime you click a link or just about anything for winxp? Also all the other windows default sounds. I did it before and now I can't remember
Don't think you can disable the clicking sound. I looked for it myself at one time and couldn't find it. All other windows sounds (startup, shutdown, errors, alerts, etc) are found in Control Panel>Sounds and Audio Devices>Sounds. Select the sound you want to change or remove at the bottom of the tab, and browse away.
