windows problem
zypher84
i keep getting that fatal error or whatever message.
not sure if its a fatal error but its that messege with a countdown to shut down windows, and then windows shuts down. im not sure what the problem is, any ideas?
i'm not sure what your problem is either.
when does it come about?
how often?
when did it start?
did you make any changes before it started?
how long has it been going on now?
what OS (9x/ME/2k/XP) are you running?
i had a post a couple days ago about a problem i had.
after a month or two of building a new system, whenever i turned on my computer it would bluescreen at windows load (windows xp) really fast. i couldnt see the error cuz it was so fast but when i ran safe mode, it would crash and restart at agp440 or something like that.
i figured this was my geforce 440 driver probelm but since i couldnt even get into windows with safe mode all i could do was reformat. now it gives me a error shutdown countdown randomly when im using the computer.
before you get flamed, google up blaster worm, run windows update, and look up blaster worm in a) this forum, or b) somewhere like symanetc.com. it's not hard to get rid of.. have fun and good luck.
