Not sure if this should be in here or the OS forums, sorry if this is the wrong spot.
Little back story: Go to the bottom for the quick and dirty.
Just bought Vista Ultimate from my University. Since I was installing a new OS, I figured I would repartition my drives to give my OS more space to breathe (20gb just isn't cutting it).
I took an unused identical 250gb drive and repartitioned it and installed windows. I kept the old Hard drive hooked up while doing this. I then spent quite a bit of time setting things up to my liking, installing apps and drives and what not.
Overnight I went ahead and did the transfer of all my storage from the old drive to the new drive. Woke up and took the old 250gb drive out, fixed the cables and went to turn on the computer and I get the "Disk boot error, insert system disk and hit enter".
I'm guessing the problem is that I installed vista with the old hard drive hooked up and it set it up as a dual boot with the other disk being the boot disk.
So I put the vista disk in and tried to repair it. It said it found the problem (said mislabeled partition) and fixed it. Rebooted and same thing.
Quick and dirty:
I installed Windows on a 2nd drive while a drive with windows installed was still hooked up to the computer. When I removed the drive with the initial install my computer gets the "Disk boot error, insert system disk and hit enter".
Is there a way I can fix this without completely reinstalling Vista, as I put about 4 hours into installing all my apps, drivers and tweaking the settings.
No information would be lost by doing this as its all backed up on the other partition, just my 4 hours of time.
Thanks for any help
Quick and dirty:
Thanks for any help
