gta95 said:So your saying create a Username/Pass on the server identical to the one of the machines trying to access it?
oakfan52 said:yes or if you don't care about security change the local policy on the machine to include Anonymous users in the Everyone group.
Axeldoomeyer said:I would recommend the password route. That is alot more secure....
To change the GPO click Start then Run type "gpedit.msc".
Expand Computer Configuration
Expand Security Settings
Expand Secuirity Options
Then find the policy "Network Access: Let Everyone Permissions apply to anonymous logins."
After you make changes to the policy you need to reboot or click on Start then Run and type "gpupdate" and click OK. This will refresh the local policies that are on the machine.
That should do it.
Axeldoomeyer said:1. If the machine is in a domain then give the share the propper permissions.
2. If the machine is not a member of a domain and is part of a workgroup all you need to do is create an account on the machine(s) that need access to the share. Make sure the account has the same password on both machines. This will allow for connectivity.
Example:
Computer Name Username Password
ComputerA rusty.shackleford somepassword
ComputerB rusty.shackleford somepassword
Note that both usernames are identical, as are their passwords. On the machine that has the share give the user account rusty.shackleford permission to the folder, lets say that is computer A. When you log in to ComputerB login with the user name and password above and it will allow you to connect to the share without promting for a password. Hope this helps. Good luck!
