Windows Installation Problem
Relentless3O
Ok, so I run the disk for set up, it formats, I make a new partition, it checks the disks, etc. I restart my comp like it tells me too, and I have to keep re-formating, make the new partition, check the disk, etc. Its like a never ending circle or formation madness. What should I do?
ok, after it reboots like it tells you remove your xp disk and it should load setup just fine... it will ask you to reinstert your disk,
