AtomicFire
- Dec 7, 2001
Re-Installing Windows SP2 Fixed it!
So last night after getting all my new WC stuff put into the case, I boot up and I see that McAfee AV has failed an update. We get 8.0i Enterprise for free from the school (I like it because its clean, not IN-YOUR-FACE-OMG-VIRUS like regular home-user AV software) so i'm thinking simple, just uninstall, reinstall, that should fix it. Nope, I get some Framework error, so I google for 2 hours, and tried 2 things:
1. run a batch script that re-registers all DLL's in C:\Windows\System32
2. delete all traces of McAffee AV from registry and hard drive
Now that I look back, #1 seemed like a bad thing to do. McAffee works fine now, updates and works and all, but now my system has a sudden inability to render HTML. Program help menus\outlook\IE, anything that renders HTML doesn't work, even Counter-Strike, when you're joining a game and that window pops up in game showing server info - it'll kick me back to the desktop and ask me to download an html file. When I open Outlook 2003, the Today screen is apparently a HTML file because now every time I open Outlook, it asks me to download an HTML file while the Today window is blank. IE, any website you type in, it looks like its trying to connect (shows "waiting for reply" in the bottom) then just goes to a blank screen.
FireFox works fine though.
I tried Windows File Protection (check and re-copy all system files that may have been modified), reinstalling IE, virus scan (nothing came up) and NOTHING works.
Help me!
Things i've tried:
1. Windows File Protection scan + restore
2. regsvr32 "C:\Windows\System32\mshtml.dll" - showed a success dialog, but didn't fix problem
3. IEFix - Reinstalled IE\Reregistered DLL's, Windows File Protection scan
4. Force reinstall of IE6SP1 with the /q command. Now I can't login at all, shows "User Interface Failure" at boot.
5. Re-Install Service Pack 2 - this fixed it!
Help me!
Things i've tried:
