Windows Explorer Help
woahthere
im getting this error when ever i go into my documents, my pictures etc.
when it happens it locks the whole system up and i have to ctrl alt del, and end my documents. iv just done a virus and spyware scan and its clean, anyone know whats causing it?
I had the same problem. Uninstall any xvid codecs you have. You might have to reinstall the xvid codec using something else.
I had the EXACT same problem and uinstalling it fixed it.
