Windows Experience Index will not run
asurething
When I try to click on the "rate this computer" button nothing happens. I have the following stuff:
SSD OCZ Vertex
2-6870 crossfire
I5-760
Any suggestions?
I had it happen once, not sure what I did to fix it, but went though and made sure I had all my drivers and every thing was found correctly in under system in control panel. Run windows update if you haven't yet
easiest fix is shut down the computer and unplug it from wall outlet, keep it unplugged for about 3-5min and than plug it back and restart try it if it's fixed, this fixed for me when i build the pc.
