techweenie
- Nov 23, 2006
I have no choice but to use an old computer while some RAM gets RMA'd, but I'm having an issue with my monitor now. The computer is a Pentium II 450MHz with 128MB RAM and a GeForce 5900xt AGP under Windows 98SE. The drivers for both the video card and monitor are installed and working properly, but the highest I can set the resolution is only 1600x1024. The card supports up to 2048x???? over the VGA connector, but only 1600x1200 over DVI. Obviously I have it connected to the VGA port. I can't add a custom resolution of 1680x1050 either. Is this an operating system limitation or a known bug?
