RanceJustice
- Jun 9, 2003
Hello all. I'm considering taking the plunge and moving up to Windows 8.1 Pro as the Windows port of my Linux+Windows dual boot.. I'm lucky enough to have a couple of those old Windows 8 Pro keys that were sold for $15 way back when. I used one of them on my laptop some time ago, which gave me a Windows 8 Pro (plus a free media center upgrade) install, which I then updated to 8.1 using the Windows Update option after being offered the ability to do so, so I know the keys are valid for Win8 and 8.1 via update at least.
That was quite a long time ago, and I'd rather not have to go through installing 8, patching months of updates until I qualify for 8.1 again, patch 8.1, and then subsequent updates after that if not necessary. Thus, I hoped I could download the newer Windows Upgrade Assistant which, I was hoping would give me the chance to create a Windows 8.1 Pro x64 ISO or bootable USB, as it did during the old Win8 version. Now, this does seem plausible except with one problem - it expects me to actually BUY Win 8 Pro at $199 before I'm allowed to download it. There doesn't seem to be an option for "I already have a key and just need to make installation media". Thus, I was wondering if perhaps you ladies and gentlemen could assist me.
Could anyone point me towards an official way to create a bootable Windows 8.1 Pro x64 ISO or USB? Perhaps there is some other utility somewhere else? I know that MSDN has this sort of thing, but I am not a member so no luck there. It would be great if there an installer that would create a version that included all the current Windows Update major updates, patches, and Media Center as well, but I suppose that isn't necessary if I can at least get to Win 8.1 Pro x64. I've seen this sort of thing slipstreamed in via "questionable" installs so I know it is possible, but I wasn't going to look that direction since I have no need of a "KMS activated" variant...at least I don't think.
Would anyone happen to know if my old Windows 8 Pro keys would be sufficient for going "right to" 8.1 Pro? I've heard that the only thing I may have to add is Media Center as I (foolishly now) forgot to use all the keys, install Win8 and convert/add Media Center a long time back. However, I just want to make sure the base keys themselves are still sufficient. On a related note, I DO have one key that I used on a laptop, that was originally installed as Win8 but is updated to 8.1 Pro w/ Media Center 64. I no longer use that install on said laptop, so would I be able to successfully activate using that key?
Thank you all. I hope this will be a smooth process.
