Windows 7 System Requirements
Nice, I guess I can really start trusting Microsoft now, they promised the exact thing with what they mentioned with Windows 7 for Vista and it was all bulldust. Hopefully I will install it now and see if it goes nice and smooth. The only thing now is that, will it run on a old skt 478 Intel Integrated graphics card?
It should, you might have to get used to not having Aero if there's no driver up to the task.
Update just tried it...didn't work...my Windows 7 Ultimate is 64Bit...socket 478 Pentiums and Celerons aren't 64Bit compatible... :(. I guess I need to get 32Bit....any of you pros know how to get 64Bit addressing into 32Bit if possible??
Its not possible if your processor doesn't have 64-bit support.
You only "need" 64-bit if you want to use 4 GB or more RAM.
