iceredwing
- Oct 24, 2007
i downloaded the windows 7 7100 build just a few days ago, is this current build different? cause i noticed that the iso has the 7100 label on it.
i got over 2mb/sec but i dl'd late at night.![]()
It uses hardware virutalization instead of software and it allows you to run programs in windows 7 from the windows xp virtual machine without actually loading the virtual machine. This isn't meant for testing but is meant for those few programs that you have at a business that won't run on Vista or windows 7 and are leaving you with the option of stay with Windows XP or purchase a new software solution. This way you can leave the software solution allone and upgrade your windows install while still running that XP only software.
For the average end user, running the program from their start menu like any other program without ever seeing a virutal machine running would be far easier and less confussing than your standard old fashion virtual machine.
have you tried installing under vista compatibility?i got over 2mb/sec but i dl'd late at night.
the company that provides my headphone drivers doesn't make them for windows 7...so i can't play games on it unless i use vista. same with my samsung printer drivers. not for windows 7. so i cant print unless in vista too. kind of a problem, wouldnt you say?![]()
Would that allow you to run 32bit based programs while using W7 64bit? Some of my work programs wont work in 64, not even in compatibility mode.
Please could someone point me to where I can get a product key for the x64 version?
Thanks.
Looks like MS REALLy beefed up their backend for these downloads, i remeber some Vista beta's people not even being able to get to the websites cause it was so overloaded!
Like with vista, 32-bit and 64-bit both use the same keys. So if you have a 32-bit key it works for the 64-bit version also.
Thanks; however, I have not fiddled with W7 until the RC - and have grabbed only the x64 version. Do I need some kind of special subscription to get a key?
