I just installed Win7 Build 7100 this morning and I cannot get SLI to enable.
When I go to my device properties my second 8800 GT has a notice that there are not enough resources available and I do not get any options under my Nvidia Display panel to enable SLI.
As I recall with the previous Beta Version of Win7 I had used awhile back this is the same issue I had and why I never messed with it further. As I understand it SLI was not an option you could use in that version either.
I have searched this forum and others and it appears that others are able to get SLI working with the latest build.
I have disabled everything in the BIOS i can live with out and the only other card installed in the maching is my sound card in an attempt to free up resources like what is being reported.
I was curious if anyone else has had troubles like this or idea's.
Thanks
Thanks
