Recycling1
- Dec 26, 2009
I'm having some trouble ejecting any type of USB mass storage device from windows 7. I have enabled quick removal and tried disabling write caching on the external drives but every time i try to "safely remove" the drives i get a message that its currently in use(even though im positive there are no programs using it or explorer windows open). A little searching on the windows 7 forums revealed that there are quite a few other people with similar problems but nothing definitive in the way of a solution. Currently having the issue with the samsung F3 drive in a hotswap dock and also on a mybook. Its not a huge deal as i just have to shut down the pc to pull them out but it would be nice to get the safely remove hardware feature of windows working correctly. Anyone else having these problems or find a cause/solution.
Thanks
Thanks
