Windows 7 32bit vs 64bit
Discussion in 'Operating Systems' started by vitalym, Sep 18, 2009.
  1. vitalym
    vitalym Limp Gawd
    295
    Sep 12, 2008
    I think that these days pretty much all software has support for 64bit, is this assumption correct? What I'm trying to do is decide if I want to use the 32bit or 64bit version of Windows 7.
    I game a lot if that helps. Does it pretty much come down to me having to research all the software/games I use to verify they have a 64bit version? A 32bit only software wouldn't work in a 64bit system right?
    Specs:
    Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775
    CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
    MSI 8800GTS-T2D320E-HDOC GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP
    GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express
  2. criccio
    criccio Fully Equipped
    11,851
    Mar 26, 2008
    Yes
    No. Unless its 10+ years old, it will probably work, and work well.
    No, it will work just fine.
    Prepare for this thread to get ugly, this question has been beaten to death many times over here and the answer is there is absolutely no reason not to go 64bit.
  3. ganesh21
    ganesh21 2[H]4U
    2,340
    Jan 22, 2006
    Most, if not all 32 bit software work on 64 Bit OS.
  4. E.E.L. Ambiense
    E.E.L. Ambiense Gawd
    764
    Jun 13, 2008
    At this point, the only reason to go x86 is if you're running it on an Atom-based netbook. :)
  5. criccio
    11,851
    Mar 26, 2008
    Or a HTPC. :)
  6. vitalym
    vitalym Limp Gawd
    295
    Sep 12, 2008
    You know I should probably appologize, I did zero searching before asking the question.
    Usually I'll search around before posting, I guess the question poped into my head and I didn't think twice about posting it.
    In any case, thank you very much to the posters, I can't wait for 64bit Win7!
  7. E.E.L. Ambiense
    764
    Jun 13, 2008
    QFT. :)
  8. RadXge
    RadXge 2[H]4U
    2,774
    Aug 2, 2006
    I have been running Vista 64 bit for 2 years and I have not encountered any compatibility problems in the last 12 months. 32 bit is a thing of the past for me.
  9. doctah
    doctah Limp Gawd
    393
    Feb 8, 2008
    We use a web based application at work that doesn't support 64-bit OS. The site uses a software made by Juniper Networks. I'm not sure if there is a newer offering, but the version we have settled on will not work in anything other than Windows 2000 and up, 32 bit, IE 6 and up. Seems all the new desktops/laptops are coming with Vista x64. This causes all sorts of headache for us (tech support).
    I also do support for a law firm that has a time tracking system that will not work in x64 (per the support team - haven't tried myself). There are still "legacy" apps out there...so saying "there is no reason not to go x64" is a bit premature.
  10. Jon55
    Jon55 2[H]4U
    2,352
    Jul 7, 2008
    /thread
  11. pallesen
    pallesen Limp Gawd
    498
    Nov 29, 2007
    I use a dictionary that is 16/32 bit. So that will not run in a 64bit edition.
  12. bigdogchris
    bigdogchris [H]ard as it Gets
    17,746
    Feb 19, 2008
    Windows 7 Professional XPM might work for you. But it's likely you're one of the few who have a reason to stay on Win 2000 or XP. There's nothing wrong with that.
  13. arcturus
    arcturus [H]ard|Gawd
    1,181
    Jun 28, 2000
    No 64 bit drivers for my sound card yet. It is available in 32 bit.
  14. Moog
    Moog [H]ard|Gawd
    1,048
    May 22, 2002
    You shouldn't have any problems with 32-bit software running on a 64-bit OS.
    I've used every 64-bit OS MS has released and the only problem I've ever encountered relating to a game has been the well known incompatibility between Splinter Cell: Chaos Theory and 64-bit OSes. Even that wasn't a problem with the game or operating system, but rather the copy-protection scheme Ubi decided to license.
    If you have problems with non-video accelerated software that needs a 32-bit environment you could always use XP-mode in Windows 7 or dual boot.
  15. brucedeluxe169
    brucedeluxe169 2[H]4U
    3,728
    Aug 24, 2004
    really? why? Can't an HTPC run 64-bit windows just fine provided it has the proper hardware?
    *confused*
  16. criccio
    11,851
    Mar 26, 2008
    It can, but it only leads to eventual incompatibilities. 32bit works just fine for HTPC's and you lose nothing so why give yourself eventual headaches if you don't have to.
  17. brucedeluxe169
    3,728
    Aug 24, 2004
    :confused::confused: still not following you....
    *full disclosure*, I run my HTPC on a 64-bit OS.... and its been through years of software updates, and OS updates.... I just can't really see how running 64-bit software will cause complications as long as the hardware is compatible...
  18. -=Antimatter=-
    -=Antimatter=- 2[H]4U
    3,342
    Feb 8, 2005
    It's still more difficult to manage codecs in 64 bit. If you're running Win7 or Vista, and you've tried to use MPC with hardware acceleration with CUDA, then you know what I mean.
    http://www.hardforum.com/showthread.php?t=1443403
  19. criccio
    11,851
    Mar 26, 2008
    When you play all types of media, SD, HD, multiple formats and containers, with and without hardware acceleration you find all the little things that just don't work.
    Like I said, you gain NOTHING from a 64bit HTPC so why bother with the headaches?
    You have found a situation where the path you have taken (combination of codec's, HA or no HA, and media type you play often) works out to be compatible, but you just got lucky. There are many other combinations that just don't work yet.
    32bit HTPC do EVERYTHING so you lose nothing in compatibility.
    No-brainer for those who have done extensive testing.
  20. brucedeluxe169
    3,728
    Aug 24, 2004
    weird, this honestly is the first time i've been made aware of this...
  21. Malakai
    Malakai 2[H]4U
    2,125
    Dec 29, 2001
    If you have a 64 bit CPU, and 2+gb of ram, there is absolutely no reason not to use an x64 version of vista or 7. Both OSes have a very complete suite of x64 drivers.
    If you have more than 3.5gb of ram, and you are not using 64 bit windows, then you have memory in your box sitting there unformatted and unused. Big waste.
    Use your hardware. Climb out of your holes people!
  22. doox00
    doox00 2[H]4U
    2,891
    Aug 28, 2005
    man, its been awhile since I formatted my memory... :)
    agree with 64bit and htpc's.. was a major headache for me as well, switched back to 32 bit.
  23. Malakai
    Malakai 2[H]4U
    2,125
    Dec 29, 2001
    Just FYI I use MPC-HC on vista and now win7 64 bit ultimate editions, with DXVA rendering on my HD4830 for h/264, and it works fine.
    Both with MPC-HC x32 and x64 editions.
    On win7, to get EVR/DXVA to work with mpc-hc (either version of mpc, 64 bit os) I needed to install a directx redist, as I was missing a dx9 file needed for the d3d rendering of video on the screen. Installed the aug09 redist and all is well tho!
    For some reason, by default, win7 does not include all the dx files that vista 64 would include, but it only takes a second to dl and install the redist.
    Hehe you know what I meant :) And yeah, it doesnt matter for an htpc, tho if I were to build one now, it would include 4-8gb of ddr2 and run win7 64. I have no problem with codecs and such on vista or 7 x64. MPC-HC and VLC's internal codecs and filters all work fine in 64 bit, and there are very functional open source alternatives like ffdshow-beta's as well.
  24. doox00
    doox00 2[H]4U
    2,891
    Aug 28, 2005
    My problem was running media center app itself, media player and other video players would use a different set of codecs then media center app itself would, causing alot of issues with playing movies/videos etc.
  25. criccio
    11,851
    Mar 26, 2008
    A HTPC with 8GB or RAM.... ROFL
    My HTPC's have 2GB of RAM and do perfect 1080p... Even then their RAM usage rarely goes over 600MB...
    You have no problem with codecs because you are not using them. MPC-HC uses its own built in filters as does that POS VLC. On my desktop I use MPC-HC too but its a player, not a HTPC frontend. I use 7MC on my HTPC.
    Its been said many times, if you play a large variety of video files in many different formats and containers, and want hardware acceleration to boot, x64 just isn't the way to go for a HTPC. I have a directory of about 100GB worth of test files (assorted codecs/containers) that I use for compatibility testing of players and codecs and every Windows 7 32bit HTPC I have setup thus far has had no problem playing back every single one. The x64 setups fail horribly.
    And that is with all the available filters/codec setups.
    Again, you gain absolutely NOTHING from trying to build an x64 HTPC except eventual incompatibilities. With 32bit HTPC you give up nothing and never have to worry about incompatibilities.
    For those who have done that actual testing (myself and a few others here), x64 HTPC make ZERO sense (right now).
  26. Malakai
    Malakai 2[H]4U
    2,125
    Dec 29, 2001
    Ah yeah I would probably not use ms products for a media center pc. Id be tempted to go linux for mythtv and such!
    I only meant Id use 4-8gb cuz ddr2 is so cheap its almost free, and everyone I know who upgraded to ddr3 platforms has tons of ddr2 lying around!
  27. criccio
    11,851
    Mar 26, 2008
    There is still no point... Your spending money for no reason = money wasted. No matter how little.
  28. Rebeldawg
    Rebeldawg Limp Gawd
    252
    Dec 22, 2007
    Actually I have an htpc and i use windows 7 x64 on it because it felt quicker
    than windows 7 x32.
  29. MeltingTmel
    MeltingTmel n00b
    48
    Sep 21, 2009
    Is there really any reason to use a 32bit OS anymore these days?
  30. doox00
    doox00 2[H]4U
    2,891
    Aug 28, 2005
    guess you did not read the thread?
  31. Jon55
    Jon55 2[H]4U
    2,352
    Jul 7, 2008
    I did and I still can't find a reason.
  32. Malakai
    Malakai 2[H]4U
    2,125
    Dec 29, 2001
    Reasons to use 32bit:
    Less than 2gb of ram
    Less than 3.5gb of ram and some program or old piece of hardware you absolutely need that has no 64-bit driver.
    Thats about it. I say less than 3.5, cause even if I really wanted a piece of hardware, I would not run with unused memory. Total waste!
  33. criccio
    11,851
    Mar 26, 2008
    Apparently you failed at reading the thread. There are two very legit reasons plainly laid out.
