SilverSliver
- Feb 23, 2004
Have installed drivers for both phones I have, LG G3 and HTC One M9. Neither phone is seen in devices when plugged in. Anyone have any idea what to do?
Having this problem with my Moto X 2013.
Manually installed drivers. Nothing.
Installed Moto Device Manager. Nothing.
Tried USB Debugging in Developer Options. Nothing.
If you really need w10, you can run Mint in a virtual machine
If it's really important, Linux has generic driver for Android devices that works very well for my Nexus 7 and LG Optimus. If you really need w10, you can run Mint in a virtual machine
If it is not showing up at all in Windows, it will not show up in Linux either.
Lol what.
I'm not the OP. But if their issue is anything like mine, just change the port.
My phone would buzz and charge from the port, but windows would not detect it.
Happens on all ports. Mix of USB 2.0 and USB 3.0. Tried several USB cables and verified they were working correctly by connecting them fine to work computer.
Is the phone detectable on another computer? What happens when you connect the phone up? Does it show up at all in the device manager?
Good to know. And no, I don't really need W10
I upgraded last week, and I've hated every moment of it. It looks great, and feels pretty good, admittedly, but it has been nothing but a headache.
It does, you simply hand over the USB port/device to the Linux VM. If you enable USB Debugging in Developer Options, when you plug-in any android device all of its partitions show up in your file explorer.
I had 4 bad USB cables...they would all charge but no data? weird
now that you mention it i ran into this once before....cheap cables i guess
If anybody is still struggling with this issue, I've found a solution:
For N and KN Windows users, we need the Media Feature Pack. Unfortunately, this also downloads Windows Media Player, which is the sole fucking reason I got the N version...
I'm pretty amazed that in 2015, I had to add a feature pack to a Windows operating system just so I could plug my goddamn phone in to copy some files.
Here's the link to the feature pack:
http://www.microsoft.com/en-US/download/details.aspx?id=48231
Waiting on the EU to sue them for all these privacy issues with Win 10 and using up peoples bandwith for BS.Blame the European Union and their "anti monopoly" practices. However, thank you for the solution, appreciate it.
