Windows 10 Pro Remote Desktop help
maclem8223
Having an issue with remote desktop on Win 10 Pro and I can't figure it out for the life of me. This is my HTPC that I am trying to remote into from my laptop on the same network. Static IP on both. I've tried the IP and pass for the HTPC login for credentials. The computer name as well. Remote is enabled on the HTPC. It won't connect using any credentials that it "should" take. Am I missing something simple. I've used this before and it was never this difficult. Can't get into the shared folder on the HTPC from my laptop either.
