Window panel kits
pedsaktix
I just transferred my components into an Antec P182 case and I thought I'd cut the side panel and put a window. Is there a site you folks can recommend for this kits?
Thanks.
what i did is got an acrylic window from a local shop (gave them the size and got what i wanted) used a dremel and double sided tape. looks very very good and way cheaper than the stuff you buy online. plus you can get the window any shape you want it.
