jeffmoss26
- Aug 1, 2002
Story:
I bought a window kit a few weeks ago. I first cleaned up my cables, and I posted those pics. I borrowed a Dremel, hoping it would be easy to cut the case for the window. Well, I was wrong. I had to use a jigsaw to cut the case. Then I struggled with the moulding that fits over the cutout. Finally got it in place, sort of. Couldn't get the piece of plexiglass to fit in the moulding. At that point I tried to just put the piece of plexiglass on top of the moulding with some silicone. That didn't work so I gave up. Obviously I didn't want a big hole in the side of my case. I took some cardboard boxes and covered up the hole. Then I went crazy with duct tape and taped the entire side of the case up. Here are two pics:
EDIT: going to take some more pictures later today.
