Window designs...
Raikiri
Well I'm working on putting together a dual loop system in a Lian Li G50... which could be interesting.
So far I have moved the HD bays and turned them 90 degrees so I have enough space to fit a rad in the front, cut a hole for mounting a rad on the roof and done the holes for mounting two fillports / cable management.
Up next is the window, and well... I'm a bit stuck here. This will be the first window I have cut myself so it can't be anything too complex.
Layout:
Template:
Thanks for your help :)
