I am installing an air conditioning unit in my office and I need some advice.
The room is 10' x 11' and the ceiling height is 8' on one side and 10' on the opposite side. I live in Southern California where the temperatures get into the 100-110s+
I am currently using an LG 9000 BTU portable air conditioner but the unit is large, expensive and the placement of the window requires the device be 2 feet from my ear, operating at a supposed 54 decibels... not to mention the hose connected it to the window heats up and probably reduces efficiency.
I am considering a window unit and was wondering if anyone has experience with cooling a room this size. The price difference between the 6,000 BTU units and 8,000 BTU units isn't significant and the rated decibels are equivalent... I figured it would be safe to overshoot then undershoot. I am looking at the following from Home Depot:
LG 8,000 BTU
Model LW8012ER
- 54 dba inside, 60 dba outside
GE 8,000 BTU
Model AEL08LQ
- No info on dba levels
Sharp 8,000 BTU
Model AF-S85RX
- 53 dba inbside, 53 dba outside
The first conflict is between GE/LG... the Sharp is a less expensive unit which is supposedly quiet but reviews are hard to find. Any input?
LG 8,000 BTU
Model LW8012ER
GE 8,000 BTU
Model AEL08LQ
Sharp 8,000 BTU
Model AF-S85RX
