Killer[MoB];1030520829 said:You could install VMware Server and then install linux in a virtual machine. You would then be able to run the LinuxSMP client on the linux VM. Your computer would need to be at least dual core (or dual CPU) 64 bit and support virtualization.
Killer[MoB];1030520970 said:I couldn't get mage's distro to work. It seems I have trouble with the stuff that should be easy. So, I did it the hard way and just installed Suse in the VM which turned out to be easy for me. My machine is running a 3027 @ a tad over 6 minutes a frame. The machine is a C2D @ 3.33. That's right at 2 minutes a frame faster than my Opty 170 @ 2.85 which is running Linux as it's main OS.
If your times are that much different on the same project numbers, it almost sounds like you are not getting the SSE boost on the VM.
... as fast as molasses in a New England February.
Isn't that where they keep painting the big barrel brown to hide the leaks? lol
