Wincdman
I
Ice Czar
Guest
came across this today
http://berns.cae.wisc.edu/pages/wincdman.asp
Windows Compact Disk Management Script (WINCDMAN)
Objective:
Create a script that handles all the necessary upgrades one might want to do with a Windows NT/2000/XP CD.
Automated Process:
Copy CD install(s) to temporary location.
Slip Stream service pack into installation.
Extract hot-fixes and service packs.
Remove irrelevant hot-fix files.
Integrate hot-fix files into CD install.
Recompile necessary cabinet files.
Extract the disk boot images (if multi-boot).
Edit the disk boot images (if multi-boot).
Remove setup prompt for CD-Key (if desired and possible).
Find any duplicate files (i.e. TEST.EX_ and TEST.EXE)
Compress any new files.
Create the ISO image.
Burn the CD with a working boot sector.
Proposed Solution:
The script will handle all the necessary file operations for slipstreaming a Windows 2000 single / multi-boot CD and integrating any hot-fixes in it. The script is written in batch code using a collection of utilities and Windows Command Extensions (won't work under Win 9X).
> More
I've worked with it for months and still can't get LSI's drivers into the install CD correctly. Heck, I've even edited the driver database by hand and no dice. For non-driver stuff it works pretty good, though.
