Winbond showing error about -5 v
carloboy
Hi,
My winbond is showing this error (at picture)
my current setup is amd 2500+ mobile @ 2.5ghz 1.93
this might be bad, but do you guys think the system can handle this or do i need to do something?
this is my psu if you think there is any relevance
http://gruntville.com/reviews/PSUs/coolergiant_eg485/
thanks for any input
carlo
hmm yeah i was wondering why it was talking about isa buses
well if it wont affect my system then i guess its all good
Few ATX 2.xx compliant PSUs still have the -5V rail. According to the review you linked to, this unit doesn't have one either.
This is not a problem, as only old(er) systems and certain components from braindead manufacturers (re MSI) still use the negative rails. Unless you're experiencing problems which might be related to a missing rail, you can safely ignore it.
ahh i see. your right about the -5v rail not being in the specs, i guess i'll just ignore this warning as most ppl here said i probably wont have any use to it if i have a newer system.
thanks guys, i was a bit worried as this being the first time to see this warning.
carlo
