- Nov 22, 2004
Ever since I bought my Asus P4C800-E Deluxe motherboard, it has had troubles reporting voltages and temperatures.
What happens is, the temperature and voltage readings are very inaccurate. Every second the temp can change by ~ +/- 8F(Under NO LOAD)!
My question is, first of all would this be caused by a faulty Winbond 83627THFchip? Im not sure if this chip is in charge of reporting voltages and diode temps, but I have a strong feeling it is.
I tried to use hwdoctor, but I get a runtime 52 error. Its not a program error. I tried the bios, mbm5, and speedfan. All showed the same symptoms (even with different bios versions). I am thinking of RMA'ing my board(its still under warranty), but I wanted to check here first.
I would REALLY like to know my true voltages and temps.
PS> I have read on multiple other forums that this board in particular, gives others the same problems. It only shows in some of the P4C800-E boards though.
