Unknown-One
- Mar 5, 2005
The question still stands.
Can you do a clean install of the upgrade version as long as you provide a valid Vista/XP key and/or disk?
Yes. Though you never need to provide the installer with a key or disk.
Install Windows 7, select the version you purchased, but DO NOT give it a CD key. It will install as a 30 day trial. Once Windows is up and running, run the installation CD from within the OS and perform an "upgrade". This time, give the installer your CD Key.
After setup completes, delete the "C:\Windows.old\" folder. You now have a clean install of Windows 7 from upgrade media.
