Win7 & Soundmax...
newxperiment
I am currently running windows 7 and an asus p6t deluxe v2 motherboard...And since I have tried to install the worthless m-audio firewire 1814 drivers, My onboard audio has not worked. I have un-installed the m-audio drivers, re-installed, uninstalled...
For the life of me, I can not get any audio out of my computer. I have only concluded that the M-Audio drivers are useless, and since I have installed them, I cannot get my computer to play back audio even through the onboard audio...
If anyone has a solution please let me know!
Hello,
I have a asus m2n-e with a Soundmax card as well. I just use the Windows Drivers and my sound works fine, even using the SPDIF output.
I would suggest rolling back the drivers in Windows 7. Go to Device Manager, then the Properties of your sound card, then Drivers Tab. There should be a rollback driver button.
If it is not there, you may need to A. Manually remove the driver, B. Try to install/reinstall the windows driver or C. Format and reinstall. I would not even hazard a guess on how difficult a manual driver removal under windows would be.
