The MS Win7 page was up briefly and the RC is coming in *May*.
http://arstechnica.com/microsoft/ne...download-page-goes-up-early-coming-in-may.ars
Vista was RTM about a month after the final RC. Think we'll see 7 RTM in June then with an August retail?
"Watch the calendar. Windows 7 RC will expire on June 1, 2010. So if you install the RC release youll either need to upgrade to the final version of Windows 7 before that date, or install a prior version of Windows. (For more about installing Windows, see installation instructions."
It's going to be a fun time when this happens. MS gave EVERYONE the OS for free. Even non-technical people were downloading and installing it as their primary OS. When it expires, there are going to be LOTS of pissed off people wondering why they have to shell out some coin to get their computer working again...
Upgrades = horribly bad evil ideas, unless you have absolutely no other choice. And seriously, if you're using beta operating systems, you have a choice... do a clean install.
I wonder if in Win7 you can "upgrade" the upgrade like in Vista. anyone know?
Why would you want to do that to yourself?
I think he's referring to the method of using the upgrade version of the os to do a fresh install. I think you had to install it without the licence key and then run the upgrade and put the key in, or something like that.
Can a beta or RC of Windows 7 be upgraded to the final version when it's released? Or would I have to do a clean installation?
I got a few Question,
1. Is this RC build like ALOT better than the Beta?
2. Will the Key we got from the Beta work on this Build to install it?
3. Say I forget to upgrade Win7 after the Deadline in 2010, is there a way to acces to my hard drive and get any thing I might need that is still there???
