Win7 Pro Folder Permissions
I did this fine on XP Pro a few years ago but Win7 permissions have me a little baffled now.
I'm trying to set permissions on a folder so that certain user accounts can have full control within the folder but cant delete the folder itself. So for example, "user1" who is in the "users" group can create and delete stuff inside "myfolder" but they cant delete the actual "myfolder" folder. Is this possible? The folder would be located on the D drive, which would be a separate partition from where Windows is installed.
Any help appreciated, thanks.
under Folder Properties -> Security Tab -> Advanced button -> Change Permissions button -> add your user -> under the Apply TO: dropdown pick "subfolders and files only"
