Hi,
Can anyone help me with a problem I'm having with my PC suddenly restarting? It just blanks out and restarts for no apparent reason. there is no pattern.
I could be modeling in ACAD all day and Viewing NavisWorks walk throughs refreshing often and it will be fine for days on end. Then out of the blue while sometimes having sat idle for a while or under low use it just happens. sometimes twice in a day. I've tried updating drivers and all..but nothing seems to help really.
I also have some weird video thing happening. Sometimes the cursor will render strange on one monitor and be fine on the other. I go back and fourth from monitor to monitor and screwy on one fine on the other. It is monitor 1 that does the weird thing. The other day, both monitors completely scrambled on me and it took a reboot and they've been okay since. the cursor seems to revert to a strange configuration of lines. One verticle line about a 1/2" high and then a series of maybe 8 diagnal lines coming off of the verticle line and heading down to the left of maybe an 1/8" long...
This is the build along with 2 Dell U2410 monitors.
1 GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
1 XFX HD-587A-CNF9 Radeon HD 5870 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Eyefinity 6 Edition Video ...
1 CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
1 Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor BX80601930
1 Intel X25-M Mainstream SSDSA2M160G2XXX 2.5" 160GB SATA II MLC Internal Solid State Drive (SSD) - OEM
1 OCZ Gold 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV12GS
2 Western Digital Caviar Black WD1501FASS 1.5TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
1 CORSAIR Cooling Hydro Series CWCH50-1 120mm High Performance CPU Cooler
1 CyberPower CP1350AVRLCD 1350 VA 810 Watts UPS
