Hi guys,
Im having trouble with my laptop HDD, it is locked read only. This isnt my OS drive, though I have a few programs on it, it is mostly pictures, music and games. A few months back I had to do a clean install of my OS drive. I uninstalled all the programs off of this drive but I kept the other data that is portable, and didnt wipe this drive. That is probably why this issue is happening. I should say first it isnt completely read only. I have installed both a program and a game to the drive today, and it didnt give me any errors. However I cannot make changes to current files. In the root directory if I right click->New there will only be a folder there with the administrator shield. If I go into another folder, I can create more types of files when I right click-new, but I get Error 0x80070522: A required privilege is not held by the client" when I try to create a new .txt document, for instance. Lastly, if I right click a folder, uncheck read only, click apply, there is no longer a blue box, but if I press ok and go into its properties again, it is read only again.
These are all the steps I have tried.
The taking ownership shortcut :
http://www.sevenforums.com/tutorials/1911-take-ownership-shortcut.html?ltr=T
Taking ownership the long way:
-Right click Drive->Properties->Security->Advanced->Owner->Edit
-Click Administrators (My-PC\Administrators)
-Check Replace owner on subcontainers and objects box then Apply
Taking ownership the long, manual way:
- Reboot into Safe Mode.
- Log on as Administrator.
- Click Start
- Type the three letters cmd
- Press Ctrl+Shift+Enter
- Run the process as Administrator.
- Type the following commands and press Enter after each:
takeown /f d:\ /a /r /d y
cacls d:\ /t /c /g administrators:F System:F everyone:F
(Answer "yes" when prompted "Are you sure?")
Clearing disk attributes:
- Start-> Run then type cmd and launch with administrative rights
- Type-> diskpart
- Type-> list volume
- Type-> select volume #
- Type-> attributes vol clear readonly
-Go back to disk management and right click on the volume and Change Drive Letter and Paths
-Click remove on the drive letter and click OK
-Right click on the volume and change Drive Letter and Paths
-Click Add and add your drive letter again
Turning UAC off:
-Click Start > Run > SECPOL.MSC.
-Once the Local Security Policy window opens, under Security Settings > Local Policies > Security Options.
-Scroll down to find User Account Control: Run all administrators in Admin Approval Mode and then disable it. Yes -> disable it. Then, click the OK button.
-Restart your computer.
So far, only the last step (turning UAC off) has given me full permissions for my drive. It doesnt give me Error 0x80070522: A required privilege is not held by the client" when I try to create a new file in that drive, and all the files are folders arent read only (although they still have the blue square in the read only check box in properties). But I dont want to have UAC permanently off in order to be able to write to this drive. Is there something I havent tried yet that you could please help me with?
Thank you so much!
- Click Start
- Type-> diskpart
Turning UAC off:
Thank you so much!
