Win7 and SSD running good... question
ToddW2
Got my new system going with win7 and my intel 80gb G2... now what do I do for "TRIM" that I keep hearing about on these forums???
Is it something I download and install or does win7 do it ?
Win7 does it automatically. It's supported by the default MS and Intel disk controller drivers.
What do you do with your Windows 7 user account and My Documents folder? Do you move them a storage drive and then create a reference to them from the C drive (SSD)?
shawnoen:you asked the same question in three separate threads, and only one belongs to you. Please don't ask things multiple times; as people might reply in separate threads which is not useful at all.
the search function would help as there are about 100 threads on SSD set up!!
1 - make sure your SSD has the latest up-to-date firmware that supports TRIM. (Intel's website)
2 - install Intel SSD toolbox... run it once just to make sure everything is up to snuff. I have mine scheduled to run weekly for the hell of it. I know it uses up some write cycles but I'd rather be sure my drive is optimized.
3- my docs - right click on it... select properties... move (change location)
Good info.
What about storing the "Desktop" files/shortcuts on a different location where can I do that at in Win7 :confused:
Makes it a hell of a lot easier than shortcuts, especially when dealing with saving files, and selecting them via browser.
All you need to do is this:
Go to the Command Prompt and type:
fsutil behavior query disabledeletenotify
if the result is 0 then you should be golden.
I would just relocate each "My xxx" files individually in property. It cause a lot of trouble to move the entire user folder and the benefit is slim to none.
Yeah, and if the Internet Temp/Cache files are not on the SSD it won't benefit browsing as much too.
I just want the "desktop" files not on the SSD for ease of storage/access and not having to use a bunch of shortcuts :D
Moving the "My ...." folders to another drive was rather simple, following the above steps (right click, properties, location, move, select new, apply, done!).
I think I will probably add another 6gb 3x2gb to my mobo and setup a 6gb ram disk for internet cache files or play with it for other shit to :D
