Win7 64-bit Creative X-Fi Drivers Hard Locking System
elektronisch
Anyone else experiencing this? It is especially noticable after I open the Creative Audio Control Panel and start modifying the setting. A few minutes later or sometimes in the process, the system hard locks. Otherwise the drivers are generally stable..
Anyone know if there are any leaked drivers floating around I can use instead?
Not had any issues either with Win7 64 and my X-Fi.
I think there used to be some third party creative drivers from kX? or xK or something like that.
No issues with Xfi PCIe in 7 x64 yet.
I am using Creative drivers 6.0.1.1347 as viewed in device manager. File is XFTI_PCDRV_LB_2_17_0007.exe.
I specifically have ignored that xfi driver that keeps showing up in windows update.
I did just run the creative updater and it says there is no driver update available. Did you check the updater?
No issues with the latest official drivers and my X-Fi Platinum + Win7 x64
