HI all. After fighting with this for the past couple weeks, I am finally tossing in the towel and asking for help.
I have a bind server running on a FC2 box ( note to FC people: Don't call it a release if you've fucked bind up. It's not a release ), and I want to use that machien for my AD dns server. It can be done, I've done it on another box that this one is replacing. I *copied* the files over.
Anyway.
I setup dhcp and named to do dynamic name registration. Here is my dhcpd.conf file:
And here is my named.conf:
So far, so good. Right now, the machines will update their reverse address, but not their forward address. And I can't figure out why. The only clue I have is when I tell one of the DCs to /registerdns, I get this in my logs ( querylog turned on ):
As you can see, it does a lookup for sql.boca\007 ( which I am assuming is a control code of some sort ), but it doesn't even try to update the forward zone. I suspect that, somewhere, the window systems are getting boca\007 as the domain name, which will not work.
Does anybody have any other ideas? I'm completely at a loss here. This setup works just fine in three other places, and I have copied those files directly to this network and just made the simple change of the domain name. I've combed through my config files and zone files for the extra character at the end of the domain name, but I simply am out of ideas.
Thank you in advance!
Anyway.
Code:
authorative;
ddns-update-style interim;
ddns-domainname "boca";
ddns-updates on;
option domain-name "boca";
option domain-name-servers 192.168.1.1;
option routers 192.168.1.1;
option time-offset -8;
log-facility local5;
option netbios-node-type 8;
option netbios-name-servers 192.168.1.3;
subnet 192.168.1.0 netmask 255.255.255.0 {
authoritative;
range 192.168.1.50 192.168.1.100;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.1.255;
host phaser {
hardware ethernet 08:00:11:14:20:b7;
fixed-address 192.168.1.105;
host hplj2200 {
hardware ethernet 00:30:C1:CE:B2:01;
fixed-address 192.168.1.250;
host moya {
hardware ethernet 00:04:75:C1:F2:DF;
fixed-address 192.168.1.3;
host sql {
hardware ethernet 00:04:75:C0:1E:8c;
fixed-address 192.168.1.2;
host nook-1 {
hardware ethernet 00:10:dc:a5:78:01;
fixed-address 192.168.1.201;
host nook-2 {
hardware ethernet 00:0b:db:c6:82:90;
fixed-address 192.168.1.202;
host nook-3 {
hardware ethernet 00:40:95:30:70:0f;
fixed-address 192.168.1.203;
zone boca. {
primary 192.168.1.1;
zone 1.168.192.in-addr.arpa. {
Code:
// generated by named-bootconf.pl
options {
directory "/var/named/";
* If there is a firewall between you and nameservers you want
* to talk to, you might need to uncomment the query-source
* directive below. Previous versions of BIND always asked
* questions using port 53, but BIND 8.1 uses an unprivileged
* port by default.
// query-source address * port 53;
acl "updates" {
localhost;
192.168.1.1;
192.168.1.2;
192.168.1.3;
// a caching only nameserver config
controls {
inet 127.0.0.1 allow { updates; } keys { rndckey; };
zone "." IN {
type hint;
file "named.ca";
zone "localhost" IN {
type master;
file "localhost.zone";
allow-update { none; };
zone "0.0.127.in-addr.arpa" IN {
type master;
file "named.local";
zone "1.168.192.in-addr.arpa" {
type master;
file "db.1.168.192.in-addr.arpa";
allow-update { updates; };
zone "boca" IN {
type master;
file "db.boca";
allow-update { "updates"; };
Code:
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.1#32800: updating zone '1.168.192.in-addr.arpa/IN': deleting an rrset
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.1#32800: updating zone '1.168.192.in-addr.arpa/IN': adding an RR
Sep 24 21:55:23 firewall dhcpd: added reverse map from 2.1.168.192.in-addr.arpa. to sql.boca
Sep 24 21:55:23 firewall dhcpd: DHCPREQUEST for 192.168.1.2 from 00:04:75:c0:1e:8c via eth1
Sep 24 21:55:23 firewall dhcpd: DHCPACK on 192.168.1.2 to 00:04:75:c0:1e:8c via eth1
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.2#4766: query: sql.boca\007 IN SOA
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.2#4767: query: 1.168.192.in-addr.arpa IN SOA
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.2#4768: updating zone '1.168.192.in-addr.arpa/IN': deleting an rrset
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.2#4768: updating zone '1.168.192.in-addr.arpa/IN': adding an RR
Sep 24 21:55:23 firewall named[15983]: client 192.168.1.2#4769: query: sql.boca IN SOA
