That. Rumor. Is. Complete. Bullcrap. XP is the best microsoft OS to date, it's just that no one gives it a chance. If you properly configure it, it is not only stable, but is very fast. Using a tweaket-out XP, I can run Doom 3 at High, 1024, 2xAA/8xAF with a Radeon 9600XT. You heard, a 9600XT. Convinced? Oh yeah, I have probably been running the same install of XP for a year now and it's still running strong.option141 said:show me the way - i find XP bloated
XP and 2K are just as stable. My 2K install has been running for 3+years and is stable as a rock. In fact the only reason I'm not running XP is because I haven't needed to reload, and there is no compelling feature to make me want to get rid of my current load...sac_tagg said:Convinced? Oh yeah, I have probably been running the same install of XP for a year now and it's still running strong.
Phoenix86 said:XPSP2.
Do you really care when it loads the drivers?![]()
How does that *really* impact your experience with the OS??
No, nor would I think it's that disasterous.option141 said:have you ever had programs that access the internet load before your network is setup? thats happened to me =/
i havnt tried SP2 - what are the pros/cons from going XP Pro SP1 to SP2?
Phoenix86 said:My 2K install has been running for 3+years and is stable as a rock. In fact the only reason I'm not running XP is because I haven't needed to reload, and there is no compelling feature to make me want to get rid of my current load...
Support Lifcycle.UMCPWintermute said:The problem with running 2000 is you're going to be getting to end-of-life problems before too long, while XP is still going strong. If you don't like all of the fancy graphical addons in XP, you can always turn them off and it looks exactly like 2k.
What, pray tell, is drastically different from 2K aside from the visual themes?option141 said:...that wasnt what i was talking about when i referred to bloated - theres a lot of pre-loaded stuff , thats all.
LOL, no, look at the link.option141 said:so the XP pro life cycle is also over?
KarateBob said:iirc, 2k w/sp3/4 do have activation, but im not sure, cause it's been so long since ive installed 'em.
ive heard people saying (on xtremesystems or w/e) that 3dmark scores on xp are generally lower than on 2k, with the exact same hadware/drivers/etc, which makes me believe xp's kernel is bloated.
sure, you can turn off all the eye candy, and disable all the services, and tweak the shit out of xp, but you still cant un-bloat the kernel.
for gaming, if xp doesnt have any necessary features you need, then just go for 2k+sp2.
also, sp1 vs sp2, id generally say go for sp2, like it or not, its gonna be required before too long.
my $0.02
...But there are bugs that affect XP that don't affect 2K. With a very similar setup as my friend I was getting +30%FPS in America's Army, and he had a slightly faster video card, and proc. He was running XP and I was running 2K. IIRC it's a punkbuster XP lag issue. It's give and take, so I kinda think it's splitting hairs.djnes said:Also, there are some slightly older games that do not run on 2000. All game designers and gaming hardware designers use XP as their primary target platform, so why go with anything else if gaming is your primary function?
Phoenix86 said:Anyways, I have yet to see a game not run because I'm using 2K, and all I do on that machine is game. All that being said, my recommendation is still XP...
