forcefed said:Seeing that hyperthreading doesnt work on win2k, will it properly detect dual core cpu's?
Win2K doesn't support Hyperthreading, Dual Cores or Dual Processors for th record
PsiberWare said:Sorry, that's just not accurate. Win 2K Pro has *always* supported dual processors, and Microsoft fully and officially supports that application. That's why the license says "1-2 CPU" on it. My old VP6 server runs dual P3s on Win 2K and has for many MANY years now.
Win 2K *can* handle hyperthreading, if it is properly set up, however, there is no "official" support (i.e., from Microsoft) for it. That doesn't mean it can't happen. It's a bit like ocing a chip. No one recommends it, however, some people do it anyway. Go figure.
To the operating system, dual core looks no different than dual processors. It's the physical placement of two cores on one die (as opposed one core on each of two dies) that is the significant distinction. The chipset sorts out the processors for the opsys, so the opsys doesn't really care about where the chips are, it just allocates the tasks and the hardware deals with them accordingly.
Personally, I'd just go get XP Pro and be done with it, since it is not a 6 year old software product you're trying to make play nice with modern hardware.
I think even NT 4.0 dealt with dual processors "officially", I seem to recall dual P-II processors somewhere in my past life running on NT4, but that was sometime last century.
Donnie27 said:Win2K doesn't support.........
Eva_Unit_0 said:Hyperthreading works in win2k. I personally used a 2.8C in win2k and the taskmanager had two cpu's listed.
The first time I tried Win2K Pro, my 2.6C crashed.
PsiberWare said:Many people use the generic term Win2K to mean either of both versions, much the same with WinXP. Since I saw you invoke the "Pro" part, my assumption (my bad!) was you were referring to Win 2K Pro.
When I see references to Win 2K made in generic, it's generally a hassle to try to figure out which *precise* flavor they are referring to, since there are several iterations, and people sometimes don't post with precision.
Which is why I was precise in my post referencing Win 2K Pro. Or Win 2K Server (more than 2 CPU licenses).
Personally, I'd prefer people say what they mean, but that's not under my control. I didn't mean to besmirsch your post, I merely intended to point out that Win2K does come in flavors that CAN handle both dual CPUs, hyperthreading, and dual cores. And some of the applications are "officially acknowledged." The trick is establishing WHICH flavor does what.
If you were offended by my assumption, you have my apology.
you need not blow away your win2k installation to enable hyperthreading or to switch to multiple CPUs or back again.PsiberWare said:As to hyperthreading, if you want to enable it in Win 2K Pro, you have to do a complete Windows installation from scratch otherwise the proper hooks don't get built.
PsiberWare said:There are a FEW of us old-timers that remember it as "Miller High Life" and it came in CLEAR bottles and was called "The Champagne of Bottled Beer"....
Which may be why I have trouble recalling non-SMP Win2K.
Scali said:The only Win2k non-pro I know is WinME, if that's what we're talking about, yes indeed, it doesn't support SMP/HT etc.
As for Win2k Pro... It doesn't specifically support HT. HT 'works' because to a non-HT-aware OS, a HT system appears as a dual CPU system, which Win2k Pro supports.
WinXP however, is HT-aware, which means it will use a HT-optimized scheduling strategy, which means the problem of performance-loss with HT in certain situations is reduced pretty much to 0. With Win2k it's generally a good idea to turn off HT if you generally run single-threaded resource-heavy programs, such as games. With WinXP it doesn't really matter.
JetUsafMech said:Well, for what it's worth....
"Windows 2000 (also referred to as Win2K, W2K or Windows NT 5.0) is a 32-bit graphical business-oriented operating system that is part of the Microsoft Windows NT line of operating systems. It was released on February 17, 2000 and has so far had four service packs. Windows 2000 comes in four versions: Professional, Server, Advanced Server, and Datacenter Server. Additionally, Microsoft offers Windows 2000 Advanced Server, Limited Edition, released in 2001, which runs on Intel Itanium 64-bit processors."
Taken from
http://www.nationmaster.com/encyclopedia/Windows-2000
