damonposey
- Nov 1, 2006
It annoys me because my laptop has 512 of ram, yet I can't find where all memory is going because adding up my processes doesn't even equal 256. Is there anything I can do about this?
If properly maintained, this will not be the case. A system with the same software installed should always be using the same amount of memory. Also, if properly maintained, you won't see a slow down either. The only way the system is using more memory is because you are loading more software (running in the background), or you are upgrading to drivers that consume more memory. Quite a few of us have systems that have been running for years, using the same OS install, and they run as well as they did when it was a new, fresh install.XP just annoys me because it eventually gets to a point where it takes more memory than it did when you freshly formatted, even though theres absolutely nothing running.
Another reason I tell people not to leave Task Manager's Processes tab at the default settings, it's just not enough info. Get rid of the User name column and add the Peak Mem Usage, Page Faults, VM Size, and Handles - then you can get a real idea of what the hell's going on behind the scenes as the case may be:
The lonely Mem Usage column very rarely is anywhere near accurate sooo...
Where did I say it was as simple as unchecking things from your msconfig? Checking on your processes list is only a small part of maintaining a system. And yes, it really is quite simple to do.No. It isn't. If it was that easy then I wouldn't be posting here. It's not as easy as just unchecking every non-ms service and startup program and msconfig. I know how to make my process list look like a million bucks, with only windows processes running. but it still doesn't fix the problem that there is memory being used that is not showing up there.
It's a shame that this has to be said on an advanced computing forum, but here goes:
1) Don't install crap, like toolbars, etc
2) Common sense
3) Keep the disks clean and defragged.
4) Common sense
5) Keep drivers updated, remove old ones and then install new ones.
6) Run a reg cleaner and something like CCleaner.
7) Keep a good AV software package installed and update
8) Common sense
That's all their is to it. There's no secret trick, as it is simple and logical. I have systems at work that are over 2 years old, with user who are not very technical. They use the system each and everyday, and they are running as fast and as well as the day I took them out of the boxes and imaged them. That's just an example, but isn't a complicated process. You just have to follow good usage practices and common sense....that's all.
Feel free to report my posts, because nothing I said was insulting. You sound like one of the many people coming for help who starting complaining and throwing a fit when they don't get the exact answers they wanted.dude, you're being a troll. I've done all of that. You haven't been of ANY help in this thread, and all you've done is insulted me, so please, do me a favor and shut the hell up. reporting your posts to a moderator as well. friend of mine who agrees is going to do the same.
