win 98 problem
aces170
i have installed win98 on my pc.when i start my pc it starts properly
for first 2-3 times.after sometime i restart it goes to the startup
logo of win98 and then either restarts or tells me
Windows protection fault.pls restart your computer.
i tried with a couple of display cards still i face the same problem.
i tried removing my ram and placing it again but no use.
Why would you reinstall Windows 98? Your computer's getting old.
-J.
When it reboots into the splash screen hit the escape key and see if anything is running in the background.
does W9x have a boot log?
it works in safe mode everytime i boot.
i have a celeron 333mhz with 64mb ram
You may also go Start-Run-msconfic, uncheck everything on startup & reboot/reboot/rebboot......If it stopped, try eliminating it using that list.
Which antivirus you got...Mcafee ??
