Arthur Hucksake
- Oct 27, 2010
Would like to think most of what you get in event viewer is completely harmless but I remember many years ago seeing this particular issue and eventually my user profile ended up being corrupted. (Win 98 and even Vista had the issue many moons ago)
Is anybody running Windows 8 pro experiencing any of these in event viewer?
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
26 user registry handles leaked from \Registry\User\S-1-5-21-2443668506-689073690-3057848115-1001:
Process 672 (\Device\HarddiskVolume1\Windows\System32\lsass.exe) has opened key \REGISTRY\USER\S-1-5-21-2443668506-689073690-3057848115-1001
Process 996 (\Device\HarddiskVolume1\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-2443668506-689073690-3057848115-1001
Process 996 (\Device\HarddiskVolume1\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-2443668506-689073690-3057848115-1001\Software\Policies\Microsoft\SystemCertificates
And underneath it says Source = User Profile Service
This is a fairly new install and I only have the most basic of programs installed so far.
All the newest drivers from relevant sites, Origin, Steam are on here.
It's starting to bug me now. Really don't want to go back to Windows 7 (Where this did not happen unless I rebooted with lots of things open)
Thanks
DETAIL -
Thanks
