Win 7 trouble with nvme drive
Discussion in 'Operating Systems' started by pentiumiiislota, Dec 28, 2019.
  1. pentiumiiislota
    pentiumiiislota Limp Gawd
    191
    Feb 20, 2018
    Hello when i try installing windows 7 onto my nvme drive i get a bsod 0000007 error when windows boots. I used msi win7 tool to add nvme drivers. Is there anything else i can try to get it working?
    I5 6400
    Gigabyte z170 h3dp
    Lite on 250 gb nvme
    Ati 4550 gpu
  2. AltTabbins
    AltTabbins [H]ard as it Gets
    19,585
    Jul 29, 2005
    Install W7 to a SATA hard drive and clone it over. Its the only way I've been able to do it successfully.
    pentiumiiislota likes this.
  3. pentiumiiislota
    191
    Feb 20, 2018
    The nvme drive doesn't show up in windows when I boot win 7 from a hard drive. Do I need a usb adapter to clone the image to the nvme drive? Thanks!
  4. AltTabbins
    19,585
    Jul 29, 2005
    You are probably missing the nvme driver for Windows 7. Grab it from the nvme manufacturer website.
    jmilcher and pentiumiiislota like this.
  5. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,346
    Feb 7, 2003
    If cloning it like mentioned earlier does not work I'm stumped.
  6. Nenu
    Nenu [H]ardened
    19,092
    Apr 28, 2007
    You need 2 KBs to get NVME drives to function:
    Windows6.1-KB2990941-v3-x64.msu
    Windows6.1-KB3087873-v2-x64.msu
    I found them among a zip update that is provided for a few mobos.
    mb_utility_windowsimagetool_B18.0213.1.zip
    They are in the Hotfix folder.
  7. ir0nw0lf
    6,346
    Feb 7, 2003
    Would one have to integrate those into the install media?
  8. pentiumiiislota
    191
    Feb 20, 2018
    The hot fixes, then cloning it from a sata drive to nvme drive worked great. Thanks everyone!
    I also had another issue where win 7 would hang at a black for 30 seconds after logging in. Turning off pci link power saving or reinstalling gpu drivers fixed it.
  9. pentiumiiislota
    191
    Feb 20, 2018
    I think a guide said to install windows to the nvme drive directly the hotfixes would have to be intergrated into the install media first.
    ir0nw0lf likes this.
  10. AltTabbins
    19,585
    Jul 29, 2005
    Ive only been able to do it once after a ton of trial and error and going over different methods. At this point we are 2 weeks off from Windows 7 being end of life, it might be a good idea to look at Windows 10.
