Win 7 Pro install help
Discussion in 'Operating Systems' started by AnIgnorantPerson, May 27, 2019.
  1. AnIgnorantPerson
    AnIgnorantPerson Limp Gawd
    195
    Jan 10, 2019
  2. aeras1131
    aeras1131 n00b
    18
    Jul 1, 2013
    Based on there site, I would install all the chipset drivers. It appears to not be explicitly called out in the list.
  3. bigdogchris
    bigdogchris [H]ard as it Gets
    17,891
    Feb 19, 2008
    That motherboard chipset does not support Windows 7, that's why there are no drivers for it. The newer versions of Window 10, the supported OS, include the Intel USB 3.1 drivers integrated with the OS. Therefore, there is no reason to make them available for download.
    Asus has a tool for customers to use to inject the USB Drivers into Windows 7 installation media to install onto newer hardware. I do not think it supports the z390 chips though: Asus EZ Installer
    This thread may also be helpful.
    AnIgnorantPerson and AltTabbins like this.
  4. AltTabbins
    AltTabbins [H]ard as it Gets
    19,180
    Jul 29, 2005
    Even if you managed to get Windows 7 installed, you won’t get far. There are no z390 drivers for windows 7. You won’t even be able to connect to the internet unless you buy a new network card that had windows 7 drivers bundled with it. After that you are still dealing with no sound, no usb, and no chipset drivers. If you find a way to bypass all this, Windows 7 support ends in 7 months anyways.
    I’d really look into Windows 10. You’ll have a much better experience overall and it’s come a long way. The new version (1903) addresses some major gripes people have with the OS including Cortana and managing updates.
    Exercate and AnIgnorantPerson like this.
  5. bigdogchris
    17,891
    Feb 19, 2008
    Well if you have an older PCIE audio and network cards you could still have those functions.
  6. AnIgnorantPerson
    195
    Jan 10, 2019
    I have 10GbE intel fiber card so internet problem is solved :p
    ballz ballz ballz. I dont want fucking Win 10 :(
    just so much to customize and unfuck so the switching costs are something I dont want to do :/
    Also some of my programs like netlimiter doesn't work in win 10. I also really loved net limiter 3. Is there a way to made it work?
  7. AltTabbins
    19,180
    Jul 29, 2005
    I wish I had a better answer. I don't mind Windows 10 as much as I used to, especially the earlier versions. It's improved a lot since then. I'd still rather run Windows 7 though and would happily roll with that if Microsoft decided that they wanted to support it. With Netlimiter 3, the company decided that Netlimiter 4 is going to be the version going forward. I haven't seen anything showing that 3 can work on 10.
    AnIgnorantPerson likes this.
  8. AnIgnorantPerson
    195
    Jan 10, 2019
    Netlimiter 4 is AIDs. I really loathe its layout and design :/ Thats actually a large reason why I dont want to use 10 hahaha. I really liked netlimiter 3 as a network tool :( I always hear about VMs and stuff. Would netlimiter 3 work in a VM for Win 10 or something? I have never really goptten around to using VMs yet.
  9. Executioner
    Executioner Limp Gawd
    326
    Apr 22, 2015
    I don't like 10 that much, but I've been using 1809 with a fresh install using Open Shell replacement, along with ShutUp10. Works just fine. Just make sure to get the Pro version of 10 so you can defer updates.
    AnIgnorantPerson and SticKx911 like this.
  10. AnIgnorantPerson
    195
    Jan 10, 2019
    yea I got Win 8 Pro DVD so i'll just upgrade/use key on win 10 pro install. I forget how it works but did it for laptop and desktop before. I think Win 8 Pro keys just work on Win 10 Pro
    i'll check out those programs you mentioned too
  11. AltTabbins
    19,180
    Jul 29, 2005
    Since you have pro, you can turn on HyperV in Windows 10 and run your netlimiter there. VMware player would work too.
  12. AnIgnorantPerson
    195
    Jan 10, 2019
    k i'll give that a shot
  13. Executioner
    326
    Apr 22, 2015
    I just did this last week. Here is how: Took less than 5 minutes for the whole process. Start - Windows System - This PC - Computer - System Properties - Change Product Key.
    As for ShutUp10, it allows you to disable a lot of the junk like Cortana, OneDrive, and telemetry, and you can always reverse if it you want those. Program is free and does not run in the background.
  14. AltTabbins
    19,180
    Jul 29, 2005
    If he installs 1903 you can disable Cortana natively. It’s nice.
    DeaconFrost and AnIgnorantPerson like this.
  15. Executioner
    326
    Apr 22, 2015
    So they are going back to the original release where it was easy to disable? Nice. Do you right-click it?
  16. AltTabbins
    19,180
    Jul 29, 2005
    Its just separated now. So Cortana has its own button that you can disable. The search and search bar will only give you local files like it used to before 10.
  17. Alienslare
    Alienslare Limp Gawd
    160
    Jan 23, 2016
    Is it done or can i advise ??
