I did and I have two Win 7 machines with two cards each. Both require dummy plugs and on all cards when there's no monitor attached. This is the first I read about not needing dummy plugs in Win 7 or Vista. I believe you but don't understand why your system is different.Try it without them.
Perhaps it's necessary with G80/92 cards but not with GT200s.I did and I have two Win 7 machines with two cards each. Both require dummy plugs and on all cards when there's no monitor attached. This is the first I read about not needing dummy plugs in Win 7 or Vista. I believe you but don't understand why your system is different.![]()
Without it, vista will not expand my display to the second card, making the second gpu client unable to run.
It appears that his cards are not overclocked, and he most likely has one of the 548-point units which produce low PPD.Zero im not sure how you have things configured overclocks prioritys but ppd one card 1 is terrible.
With priority, I just have the GPUs run a higher setting to prevent them from starving for CPU cycles and then set whatever else I'm folding with to a lower setting. That way I get maximum performance from my GPUs. You will need an affinity utility to set this correctly.
I dunno if im late to this convo.... BUT,
You do not need dummy plugs to run Windows 7 and Multipul GPU2 clients AFTER you update Windows 7 with all the latest patches and updates.
Micro$oft was very VERY fast on fixing this issue, which amazed me, but it was actually a problem with the intergration between Windows 7 AND DirectX, gotto love it!
YMMV, I still need dummies, all up to date. 8800gs & 9600gsoI dunno if im late to this convo.... BUT,
that does make sense.Zero2dash, so no dummy plugs on Win 7 at least for GTX200 series cards.
