Win 11 bootable memory stick
Stanley14
Hi all,
I’ve built a new system and want to make a bootable memory stick for win 11, is there any guides on how exactly to do it ?
NattyKathy
I'm having issues loading all of Microsoft site right now but I believe this page may be what you seek
It's pretty straightforward:
-download Windows 11 Media creation tool on another PC
- plug USB stick into other PC
- use automated tool to download Windows installer to USB
- make sure new PC is set to be able to boot from USB and any other BIOS settings that you may want to change before install are set
- plug USB into new PC, boot, install Windows
NattyKathy
Thank you , will try
should work, this is the "textbook" way.
The only caveat is I'm not sure if that link I posted is broken or not 'cause it's still not loading for me (could be my ISP) but the "Windows 11 Media Creation Tool" is what you want, be sure to get it directly from Microsoft
pendragon1
Extremely [H]
its workin here. op get this one to make the usb. it used to be clearly labeled "Media Creation Tool"...
