I'd have to say no on the 120's, they're just too friggin massive. To make sure, rule out two 12cm strips of paper about an inch wide and then lay them evenly over the centre of each socket, they should overlap or come mega close, if not, then you might be in luck.
I'd go with two xp-90s which should fit or maybe even two cnps alcu 7000's
