JLGatsby said:I know XP did not properly recognize the last 1GB in a 4GB set up, will Vista be able to recognize 4GB completely?
byne said:unless i am mistaken... 32bit addressing only allows for 3GB of memory.
Try 16TB.byne said:64bit allows for a whole lot more than we will have in the forseeable future (40GB or something, i cannot remember).
that link definatly explained it all if you read down further.mikeblas said:2^32 is 4,294,967,296, which is four gigabytes. 3GB is 3,221,225,472.
LATER: Oh; are you thinking of virtual address space?
Which link? The one I posted to the article I wrote? Thank you!byne said:that link definatly explained it all if you read down further.
Scoobydo said:Windows reserves 2 gigabytes for its own use. So to make a long story short, on 32 bit applications, any program can use up to 2 gigs of ram, and the system will reserve 2 gigs of ram... So I do believe if you have 4 gigs of ram it will be used, however, your programs are still limited to 2 gigs of ram due to operating system restrictions. However, you will never be wasting your 4 gigs of ram in a 32 bit world, its just that these kernal/OS operations will be taking/using 2 gigs of that available ram internally.
I don't know how well I explained that but... My guess Vista will be written with 32 bit and 64 bit like XP is done today, and will probably have similar restrictions as the kernal was probably not rewritten from scratch.
mikeblas said:Either 2 GB for apps and 2 GB for the OS. Or, 3 GB for apps and 1 GB for the OS, if you've booted with /3GB. Vista won't change this.
Not to make it a semantic argument, but I'd say that the OS can always see 4GB of physical memory. It has to see its own memory and the memory of the processes it is running. The processes? Indeed, they might see less physical address space.
byne said:if i am understanding what the OP is saying, its not that he cannot fill up this space, but xp does not see it. as in... on the computer properties it says he has 3GB physical. This number does not exclude the memory reserved for the os.
byne said:so, for clarity, lets go through what it might be:
